Hey, I have been trying to copy settings from my v2 software to v3, v2 was working fine. I am now trying to start up the car with the V3 and I’m not getting trigger signal anymore. It worked fine with v2 and I copied the settings best I could. Another problem is the DBW, I was able to run the DBW calibration tool without problems but now the throttle doesnt move when I press the pedal and it stays at 41,6% in the log. I have v2 from working state and from my v3 here.
I got the car to start when I put wasted spark on startup and inverted phase on firing order, but the throttle pedal doesn not move the throttle body, it worked fine with v2.
Did you follow the help for dbw, tps and pps ?
If yes, what is unclear for you it would be the best ifbyou understand how it works. If the help is unclear please ask here, i will answer, and also updatw the help.
I was able to get throttle moving by assignin tps input into pps, like the guide said. However the car does not idle at all, I was able to get it running by pressing pedal but as soon as i let go car shuts down. If i change idle action delay to 0s its runs with over 2k rpm. And after all this I tried to do dbw calibration again which runs untill it says throttle can go into limp position.
Probably you pps check table is wrong.
You can disable 2nd pot from the menu so it will disable the palusibility check.
You can also check the status of the pps by looking into channel pps main status and pps check status.
It will indicate you the problem.
Also it looks like your idle controler is not set up properly.
Do you have any idea why would my second lambda which is controlled with emu lambda to can doesnt work anymore? I have set it to 500kbps with ligth client before. And I have same can settings that i used to have in v2. Can doesnt state errot and bt to can works fine.
