I have questions about MAF to MAP conversion
As i know the conversion must be done with load input and modified input setup table and after that the modified should be set to zero and output offset to 2.49
Here also i want to ask if i can log and gather data for conversion using table setup zero with offset 2.49
If you choose to use the “convert MAF to MAP” feature, please be aware that the offset will not affect the conversion process. The strategy for calculating values in the table relies on raw analogue input values.
However, if you opt to calculate MAF to MAP using the analogue out option, then the offset will indeed have an impact on the final table generated.
