Hi..hope all is well ang good.. i need help configuring the digital input pins for ecumaster black.. i need to wire in my ac compressor and power steering pump and auto transmission for idle up.. i cant seem to find if AUX 1-6 is the digital input or which vacant pinout i can use for them.
Aux are outputs, use them for controlling things like AC relays, fans relays, etc.
Switch inputs are able to be used for digital low side (path to ground) for things described. analog inputs can also be used if they are available.
Oh.. so ok, as i understand that the analog inputs 1-6 can be selected as digital in the software manager.. ill use the analog inputs wires then.. thanks..
