Duratech idle status
Duratech
Hi ,
I am having issues getting the ignition idle to work .
The parameter dont show that any idle status or change in advance
The car is a Fiesta st150 running throttle bodies with no idle valve and uprated cams
I am new to the EMU range so its probably something stupid Ive missed but as this is my first post I am unable to upload logs or maps
I would appreciate it if someone could look through the link attached
Have read the manual and the HP Academy Web topic on EMU idle control
Thanks Dave
have a log to go with? I think you need a few more posts and then you can link direct to forum
You need to use the correction table when not using a PID loop. check the box for the table and then make it look more like Andre’s from that worked example lol.
It’ll take some playing with, you’ll probably also want to add a custom correction for cold start idle as well, or just baby sit it when cold.
