E34 M50b25tu emu classic + pnp adaptor
Trying to set my emu classic up
Not getting anywhere really
Fuel pump doesn’t prime. Test shows no voltage change, stays at 12v
I’ve confirmed all the pins are correct
To my knowledge the adaptor comes from the OEM harness and all the pins are 1:1 /A1 to A1 and so on
I have triple checked this with continuity
Car starts fine with OEM ECU
Here is what I’ve back proved and tested
Tps shows a consistent change but only from 2.3v to 2.6 at a push
Using body earth
Tps brown wire shows 5v
Brown and black shoes the 2.3v to 2.6v change
And red/yellow show 0
  • B23 → B18: latest = steady 5 V
  • B18 → B24: latest = 5 V
  • B23 → B24: latest = 0 V
  • B12 → B18: latest = 2.3 V closed → 2.45 V WOT
  • B18 → body: latest relevant result = 0.04 V
  • B24 → body: 0 V
  • Main power → ground: 12 V
  • TPS 5 V → TPS ground: 5 V
  • TPS itself: 1.4 → 4.8 Ω smoothly
  • OEM sensor ground → adapter sensor ground: 0.5–1 Ω
  • OEM sensor ground → body: 14 Ω
  • AUX 5: 12.77 → 12.72 V during test
  • TPS software: ~0.2 V, doesn’t move
Thanks for any help
I’m losing sanity here
All sensors using the sensor ground don’t work
I think the emu classic has an issue internally but idk how to confirm this
Figured out the wiring is meant to be backwards to the pins on the ECU
A1on the connector actually goes to A8 on the ECU
According to the laminated diagram that comes with the ECU
I’ve got everything working
Car runs but I’m diagnosing my tps reading now
I’m getting an alternating voltage from the 5v supply to the sensor ground on the tps plug
Of around 1.7v to 4.9v
It flickers between both maybe once or twice a second
Coolant temp does the same from 1.7v to 3.5v
Sensor ground to 5v supply on the ECU actual pins gives a steady 5v so ECU is fine
Everything on the software reads steady consistent results other than tps which gives me very erratic readings when on the throttle
And sits at closed throttle jumping from 0.22v to 0.55v
It seems to double depending on base voltage
1v becomes 2
2v becomes 4 and so on
Causing massive spikes in tps reading
Trying to diagnose
