Bmw m44 + itb + emu classic
At frist I want to say I have neve work with any ECU.
I have bought the set of ITBs with injectors, Bosch LSU 4.2 Wideband O2 Sensor, harness adapter. The setings for the EMU CLASSIC from the seller is bad. It is not allow to start and run the engine. I have made some settings by myself and now engine is starting and runnig idle. But I have en issue with setting up VE table.
I do not understand why VE in Tune Display very different from value in the table but the correction not big. Because of this Autotune putting wrong values in the table.
Probably u are in the second VE table…there are 2…have a look on the second one.
It is a first one.
Second one not used.
Can u share a log and project?
I did not save the log.
I will make new one and share it with the project.
Thank you.
here is the logs and project
