How i can wire the pin 18 on grey connector ? With relay ? With fuse ? Ignition switch or +12v battery ?
Thank you very much
switched power, minimum 18 awg, a relay controlled by the vehicle’s ignition switch is ideal.
Relay should be fused, 10A is fine. Pair the output with the injector’s 12V feed so the ecu’s voltage and injector voltage is the same.
Ok thank you very much
Mmmmm fairly certain this type is covered in the training manual actually
Middle pin is 12V, the other two outside pins can go to a PWM capable aux or h bridge
Connect the other pin to a AUX output with a Flyback diode for protection.
Ok thanks, can do you give me a link in amazon or something like that’s please ?
