Wiring EMU Black colt czt (4g15T)
Hi everyone,
im looking for help with almost ready Mitsubishi colt/Emu black Jumper.
I’m not sure about pins from my ecu. Where should these pins be connected to Emu black?
Throttle Valve Servo Relay
Starter RELAY
IGNITION SWITCH (ST) - starting system
Engine Control relay
Cluth Monitoring Switch - 12v AUX?|
J/B Fuel Pump Relay 2 if i have two fuel pump relays, shuld i t be pluged to two different aux pins?
A/C one wire which is conecting ECU and A/c compressor. I guess that it’s A/C cluth
It will be great to get answer to my question above. I can share full jumper pinout when i finish it. Thanks in advance!
Actually u can connect most of the stuff to whatever output/input u want. Afterwards u can assigne it via SW to the correct functions.
U just need to know if u need hi or lowside output for ur stuff…if u need a highside output, u should connect it to H-bridge. Lowside doesn’t matter where. U can also put two relais to one AUX output.
For inputs u just need to know if u have a switch to 12V u can’t connect it to the switch ports…everything else doesnt matter.
Did you get Mivec to work ?
