Idle control valve 3 wire
Hello, could someone please tell me how to connect the idle control valve to the Ecumaster Classic please ? I have a this model. The part number is : 13411433626. How to connect the 3 wire ?
Thanks :wink:
Hey, Iโ€™m already familiar with that valve and can tell you itโ€™s a bit tricky to control. I tried it once and got it working somehow, but not properly. Iโ€™d therefore recommend switching to a simple idle air control valve, like the one from the Audi S2, which can be controlled just like a boost pressure control valve. Still, you can give it a try. Pins 1 and 3 are the positive and negative terminals of the actuator motor, and pin 2 is +12V. You can then control the motor like a throttle valve to open and close it.
