Hi i did custom can for 4 egt sensors from emu pro if i put canx file into display value stop at 255 ° is there a bug or something? i used 16 bit singed *1 or raw for the egt channels like egt to can strema
Can you post either your calibration files for both ADU and Pro or at least screen shots of your settings?
Does it work in the EMU pro software? is the error in the ADU software or only on the display part? you can see the data from CAN
Please also show us the ADU import settings.
I see nothing wrong here.
Make sure the “rx_proegt” is set to receive on CAN 1.
Check the “c_snsr_egt1” channel values in the ADU graph log.
Okay, let’s take a look.
Post logs from EMU and ADU where the EGT in the ECU exceeds 255.
i can do this on friday evening, car is 200km away. adu i have to connect usb. I make logging only over pro
