EMU Black + Bluetooth adapter + EGT to CAN
Hi EMU community :grin: ,
i am new to the standalone game and to EMU. Right now, i am trying to setting up my future setup. It definetely will be a EMU black.
Now i want to connect a EGT sensor (one for all 4 cylinders) to the EMU (additional to several other sensors as oil pressure, temp,….). The pineout plan says that i can connect up to 2 EGT sensor directly to the EMU. But a colleague of mine told me, that the measurement via EGT to CAN adapter is more accurat than connecting the sensor directly to the EMU. Is that so??
Additional to that i want to read out most of the engines sensors via my android double DIN. For that i want to connect the bluetooth adapter to the EMU.
Unfortuantely the wiring is not clear to me. If i want to run both EGT to CAN and CAN to bluetooth how would be the wiring? EMU does have 2 PINs for CAN High and Low. Do i need another adapters?
I hope you can help me out :sweat_smile: .
Hi.
Did you get help for this?
I am looking to install the BT CANBUS to my Black which already has the EGT CANBUS installed.
check if Dash Hub can be installed on your android head unit/display/tablet/phone etc.
if yes, then you can connect to the devise with the bluetooth module.
Dash hub has a fairly detailed instructions to follow aswell as the Ecumaster bluetooth module.
No unfortunately not. Have to check the different documents inside the homepage. Maybe this helps.
