Emu black- dbw/rpm increase
I have recently got a first start done on my Cosworth YB engine.
I am using a Bosch 68mm throttle body and calibration wizard has been run successfully.
When the engine is started, it won’t have a steady idle, the rpm increases on its own.
If I unplug the throttle body and start the car, the idle remains steady.
Is this likely to be a setting issue within the software that needs to be changed?
Ur idle settings must be wrong. U probably have a too high idle valve DC in the base table.
I eventually sorted this issue out. I ticked the Invert motor direction, and Pos sensor input to B4 and Pos in sensor input to B17.
What part number did you use for the 68mm throttle body in the dbw wizard?
It was probably one of the Bosch items in the wizard. I dont have a note of it though
