Emu Black Traction control DBW correction support
Hello Folks!
I have successfully put traction control in operation on my emu black.
It is reducing torque via ignition retard only. The reason why i do not cut spark or fuel is that will result in pops and bangs which stress the engine. Or do i do here anything wrong?
My track car will be operated on gravel and therefore just reducing the ignition angle produces not enough torque reduction. Therefore, it would be very useful to reduce drive by wire target position depending on the traction control torque reduction value.
I have seen that this is possible within the emu pro software but i have not found it in emu black software.
Did i miss this feature anywhere?
If not, is it possible to add this feature in a next version of emu black software?
Thanks in advance!
Lukas
