Emu Pro Wankel / Rotary engine Trailing Ignition Settings
how can I extend the table for trailing ignition under ignition - Trailing Spark - Delay.
By default it has only two data points per Axis which will not be enough for a 13b-REW Rotary engine. Adding datapoints did not work for me. Or am I pointing to the wrong table for the trailing spark? On the screenshot you can see that the Xpoints as well Y is greyed out
best regards,
Slash200
Found the problem, i have to set the steps to get a finer resolution. Sorry new to EMU.
