Emu Black Vss from OEM CAN
Good day folks. I just finished fitting an EMU Black to my camper van (M111 2.3Kompressor, converted to turbo) And i was wondering if it’s possible to read out the VSS out of the oem can, after fishing out the adress, id, and rest. In the Sensor menu i saw that vss can be read out of the CAN, but i’m not sure how to set up the user defind can stream to receive. Just a base file with a configured user can template both to transmit and receive would be helpfull. Thanks guys! Cheers!
CAN Wheel speed.emub (145.5 KB)
Here ya go. There’s obviously some variables to overcome depending on how the CAN data is sent, but this should explain the other part.
see tab “extra 9” for all the relevant parameters laid out, and User Defined CAN stream
Thank you so much ! I’ll try tomorow to finish the STI, then come back on my own project.
