ECUmaster CAN Stream DSG and Haltech Dashboard
Hi Community
I have trouble, with CAN Stream. A Volkswagen Golf, MK2 from 1990. This Car was build, with DQ250 gearbox.
All worked fine, but my customer changed to a Haltech IC7 Dash. I’ve changed the Dashboard CAN stream to Haltech V2. Now, the dash works fine, but DSG does not move.
When I go back, to Volkswagen Dashboard, the Car drives fine, but Dash doesn’t.
I’ve tried to build custom Can Channels, but I do Not know, what is needed, for DSG.
Problem solved.
I’ve programmed a microcontroller now, which translates ECUmaster CAN Bus to Maxxecu Protocol🤣
So, the haltech can read from the Maxxecu CAN broadcast😅
Can you breakdown what you used and the steps to getting this to work, please?
