EMU pro messages when selected output over can
When using the emu pro, and set the output channel for starter relay and engine fan over CAN,for example, will be created automatically a message in addition to the emu black stream ?or you have to manually create your own message with on the project tree for it? for all the messages that you need? thanks
It doesn’t create any new messages.
You can either use the data already available in the EMU Black stream or create your own messages.
Selecting CAN as an output is just an indication for the tuner that it’s assigned, but not using the ECU outputs.
