EMU Pro working voltage range
I was wondering what the working voltage range of the EMU Pro 8 is? The reason I ask is because I was considering running a 16v battery and charging system on my racecar but I need to make sure the EMU can handle that voltage. I was also just curious what the minimum voltage it could operate at is, might be useful in case I have a charging system issue.
Thank you!
-Spencer Constance
I could swear I found a voltage spec somewhere in the manuals or pinout sheet but can’t find it again.
The Black is rated for 6-22 volts and I’ve found it can actually go as low as 6V without turning off.
Are you looking at a total loss system for a drag car or 16V everything?
EMU PRO has the same rating as EMU Black.
The constant supply voltage can be between 6 and 22 V.
16V everything, although some people run total loss in the Micro Sprints I’m running so its nice to have the option although I don’t want to risk it personally. Thank you for the info!
