Hello everyone
I am using a stock throttle body on an s65 engine with an emu pro 8 ecu. I have completed the communication via canbus. The iddle valve settings are fine and it works fine on the rpm I want. It completes the adaptation, but when I want the throttle body to open 0.1, it opens too much and the vehicle rpm is 1800 rpm when the throttle body is open 0.1. It becomes impossible to travel by pressing the gas pedal less. Thank you in advance for any help. I apologize in advance for my bad English.
Please post the project and log files with the problematic situation recorded.
We can’t help without data.
Thanks for your answer. I am sharing my project file. I will share the log and video as soon as possible. Thanks.
I’ve asked for permission to view the file. Please grant me access.
Sorry,
I have edited the link privacy, now everyone can access it.
Thanx
Thank you for the access.
Could you please also attach a log file showing the issue?
Hello
I am sharing the link of my log file and the video link I created to be more explanatory. Thank you in advance for your help.
log file link ;
video link ;
I try firmware version 110.6 and 116.2 but nothing changed prolem.
It also may be caused by the mechanical issue. Maybe cleaning and lubricating the mechanisms will help
Hello I tried throttle actuators from another working vehicle and the result did not change. I cleaned and lubricated the throttle valves and they are working fine and smoothly, but my problem did not get better. Thank you in advance for your help.
Did you change the throttle electronics and position sensors also?
Yes. I tried it from a vehicle that was running smoothly. Also, the tps and throotle body in my vehicle worked fine in the other vehicle.
