I’m using Bosch 0 280 750 036 throttle body on the 1.8T 4 Cylinder VW engine, did the calibration, but when i open the pedal completely to the floor the throttle body only opens to 50%
Any ideas why ?
hi here look at the base file for emu black for 1,8t hope it will help you
1.8T BAM EMU Black PnP w_OEM header - Google Drive
You likely need to calibrate your TPS voltages under sensors setup. I’d start there and confirm that’s correct.
