Engine start DQ500 only possible in P or N
Hello, I would like in my S3 8L with R32 with DQ500 and Emu Black V3 that it only starts in P or N. Alternatively, only when the brake pedal is pressed. In the V2 you could adjust that the engine only starts with the activation of the brake. I haven’t found it in V3 yet. Can someone help me how I can program this?
Greetings Michael
Hi Michael,
I did such a project this summer with DQ500.
Can you share your map and log? Otherwise we can do a remote session too.
Servus
Sorry, i don’t want to publish the map because I had it made by a company and I don’t like it if you put it in the www.
For me, the question arises whether there is a function for this in the V3?
In V3 this behaviour is the default one.
So you can start on P/N or any gear if the brake switch is pressed.
My engine also starts without the brake being pressed. Is there a function that I can select that only starts with the brake applied and if so where? I haven’t seen that yet.
The problem is that the regulations state that the engine may only start in P or N. That’s why I always have a complaint. In the UDRA racing series (United Drag Racing Association)
I add for the next build option that engine can start only on P and N.
Please check your brake switch state as it can be all time on. (brake switch log channel).
I checked the switch in the emu. Everything is fine.
You dont have to share the `tuned file` but simply your config and logs when you perform this test.
In the project I have build, I didnt have this issue…
I’m not sure how to share this… if it’s selectable in the next version that it only starts in P and N, everything is fine. Then it should work.
But thanks for the offer.
Greetings Michael
It is implemented already. We are tsting new build and if everything is ok it will be released tommoror or in next two days.
Great, Thank You.
I’ll give you feedback on how it works for me.
Hello, I just flashed the new firmware 3.070 and tested the start in P or N.
He doesn’t start in any gear. It works as it should. Thank you
