Evo X can bus problems
Hello all I have an evo x with emu pro 8
Only some of the can items work.
Missing are
Wheel speeds, all center diff stuff, the coolant temp gauge is offset too high, no ac condensor temp and possibly a few more.
Anyone have any insight?
Hello
In the help panel for “Vehicle / CAN stream / Type” setting you can find the supported features.
Fot the Mitsubishi Lancer Evo X
ECU sends:
  • RPM
  • CLT
  • Fan speed
  • Differential lock
  • Estimated torque
  • TPS
ECU receives:
  • Steering wheel angle
  • IMU
  • AC state
  • AC pressure
  • Wheel speed
Perhaps there were some differences between the production years. If you can provide a trace file with the CAN communication from driving a car I would be able to verify the received values.
No problem I emailed as well
