Ferrari F136y engine VVT control
Hi all , has anyone had any dealings with the F136y 4.7 v8 engine , i have it running sweet , but want to confirm i have the VVT set right
Cheers Keith
post your map i can take a look. Best Regards Jürgen
Hi buddy , its almost there but not quite
Raf-F-40-vvt-01-08-2024.emub (145.6 KB)
Do you use the stock engine? your VVT is not working like this your cam1 map is empty
Hi Juergen , yes i was trying get both cams working , Greg ended up sorting it for me , i had some settings wrong , it works fantastic now , thanks for looking though i appreciate it , cheers Keith
Hey woody,
Would you mind sharing the updated map / project?
I am just about to start my first standalone install on this motor. It would be so helpful to verify I set up sensors correct, strategies, vvt, etc. Thank you!
Hi buddy , i dont have a map as such , i just work on your file , i can help you no problem either Team viewer and or your tune file .
Cheers Keith
