Hi folks, The current project I am doing is Turbocharging a 2022 Suzuki jimny K15B
I have a EMU Classic installed parallel with the oem ecu, everything works great so far, the only problem I have is that the oem ecu will keep a 13% throttle opening resulting in a 23kpa MAP reading when I’m decelerating. If I make the FC under pressure to 23kpa it works great as expected, unfortunately when you drive in higher RPM and Light load you can register a 23kpa situation and of course it will cut fuel then. Resulting in bad drivability
Is there a way we can add a logic to the fuel cut under pressure to maybe Pedal position? Using a analog input? Or maybe Vehicle speed?
The oem ecu drives the e-throttle body and I am using that as tps signal.
Any ideas? Thanks
