Fuel Usage from Flow
Before I setup a custom math channel, is there a way to use fuel flow to calculate fuel usage that’s already built into the ADU? On the factory Canams we are doing the ecu has flow on the canbus. Generally I’ll convert that to ml/s.
There is no built-in fuel usage calculation from fuel flow in the ADU, so you have to do it with math channels. But you do not have to start from scratch. This was already covered here:
Awesome, thank you. I had searched and missed that.
