Trip data for two fuellines
i want to freeze distance meter 2 as long as a specific channel is 1. If it is 0 again it should go on counting.
Has anyone an idea how to do this? I can’t find a simple way.
You need to create a function that converts high state into clicks.
An example project is attached bellow.
freezeDistanceMeter2.adu (5.5 KB)
Thanks a lot…i will try this.
Another question…i want to have a total used fuel channel useing fuel used message from emu. So basically i want to sum up the fuel used channel with every drivingcycle. I think this could be somehow possible with autosaved channels, but i cant find a logic how to do it. I somehow need to save a value just at ignition off (the last total fuel value). How is this possible?
That’s how the “Virtual fuel tank” function works.
Check the ADU manual, page 155.
U are right. But it will just partielly solve my full problem.
My full situation:
I have two fuellines in my vehicle…Gasoline and LPG controlled via EMU black.
I want to track trip fuelconsumption/count and trip distance for each fuelline seperatly. Distance seems to be no problem with 2nd distancemeter and the freeze channel.
With virtual fueltank i just could track the combined fuelcount.
So i somehow need to track fuelcount of one system seperatly somehow with the fuel.used emu channel and the channel which shows which fuelsystem is active.
Do u see a chance to do that?
I have this logic atm running on a seperate device and sent it to ADU…but i want to swap it completly to ADU.
Have a look at the Road/Stage functionality FW 104.
Maybe you can use Road Mode to track gasoline and Stage Mode to track LPG usage.
Aaaaah…u are right…i actually didn’t really understand this stage and road mode concept. But it seems i can cover everything…distance and fuel…with this function…thx a lot :slight_smile:
