I have an issue with random knocking sound from the fuelrail when the car is idling (+ it seems to be happinging when i rev as well). I can physically feel it in the rail, but no other place. FPR is mounted 5-10 cm lower on the firewall, but i can really feel it there. The feed needs is not optimal routed to the rail and has a highpoint of 5 cm ish above the fuelrail.
when the knock sound occur, i get a 10% ish rich spike afterwards.
i do not have a non-return valve, so i tried just running the pump for a while before starting, which helped a bit, but non conclusive.
i saw that my injector dead time was a bit out and have adjusted these now, but not been able to test afterwards.
im guessing this might be air related or “all the above”. Has anyone experienced such a thing before? tips? Im going to weld the fuelrail so i dont need the highpoint.
