V3 - Async Acc.Enr issue/bugg?
So i recently had an issue where i had phusical knocking in the fuelrail at idle. Found out that it was async acceleratio enrichment kicking for no apparent reason. it was set to 5 %/s tps rate min, but the tps rate was 0 until (dbw, tps, pps etc had no change) when the aAe kicked in. Immediatly after aAe kicks in, the tps rate goes to -21, but i cannot see any change in dbw, tps or pps. So does anyone know whats going on? anything else i should log? This happens when idle is active, but theres no changes in the values there neither.
Is there resources where i can read up on how all the functions and strategies work for emu black? As an engineer i dont get why its so hard getting insight on how these things actually works.
Do you have log file ?
yes, here you go!
its croped though since it was more that 8mb, tell me if you need more and i’ll fix
Edit: the timestamps seems to be 2:01.7 in the new file, but in other cases there is movement of the dbw while the car is in idle. I guess the triggering of aAe triggering in idle might be as designed.
20260530_2144.emublog3 (275.2 KB)
