hi, on my v2 i simply used a parametric out to setup my shif light.
can someone help me to set it correct with the function. at the moment its blinking all the time
If the RPM > 6000, the output will flash. The only drawback coulb be that in worst case scenario there will be 0.3 sec delay to turn on the shiftlight.
Other method is to use two functions. One for RPM > 6000 and then second when you use flash and previous function as an activation
