Gear Selector Font, for Coolant Temp?
Has anyone worked out how to use the Bold, Italic style font from the Gear Indicator on any other value?
I want a massive coolant temp indicator in the centre of the screen, and even if you choose a ‘gear indicator’, and select ecu.clt as the channel - it only displays 1-8 + R numbers.
As I read the documentation, the Gear Indicator UI element is designed specifically for Gears.
You need to use a Text UI element and then pick a suitably large font. You can set the checkmark for Italic font.
super rad layout btw :+1:
Yes I too have read the documentation, but I’m hoping someone has found a workaround, perhaps uploaded custom fonts - because just making it big, and italic still looks very basic.
This layout needs the font to to be the super bold and modern style, to match the ECUmaster type face.
