How to enable asynchronous accel enrichment (without synchronous accel enrich)
Does setting “Acc.enrichment type” to “Disable” turn off all forms of acceleration enrichment or just the synchronous enrichment? How do I enable asynchronous enrichment only? Selecting Disable grays out the upper portion of the dialog, but not the asynchronous enrichment settings (suggesting asynch is still active). With the settings as shown in this screenshot, I get no asynchronous enrichment.
You need to select Acc. enrichment type, as it define if the Y axis is MAP or TPS rate.
To disable synchronus enrichment, fill the whole Acc. enrichment table with 0.
Understood. Thanks for the clarification.
