Hi!
I got my self an adaptor and the Ecu emu black, loaded in the base map and it’s running really rough.
Afr:9 at idle (at normal op temp)
Lot of sud and bopping, no Knock triggers, it’s hunting at idle from 500 to 700rpm. All inputs and outputs are valid and tested.
so my question is: I heard that the base map of the st225 is made by a employee of ecu master for his personal car. And I wonder how to find TDP (without markers on the engine block)
So I find tdp with a micrometer (gauge). And then find tdp make a marker and then lock the ignition at 10• before tdp ?
like I was under the assumption that this map would run decent on the stock ST
Greetings and thanks for the help in advance!
