How to Program PMU to have keypad buttons trigger CAN messages to be transmitted?
Hi there,
I have a VCU which looks for CAN messages to enable PRND. Is there a way to program buttons of the CAN keypad to transmit a CAN message for each P, R, N, D? The buttons should be in their own Radio Button Group as well.
I have the messages which the VCU expects for each P, R, N or D.
How complex is the CAN message? You can use a CAN export to send a custom message, might need to be a number function between the keypad button and CAN message, but using a custom multiplier on the CAN message might do.
Alternatively you can setup a table with each button state correlating to a value and transmit the table value.
This software is so flexible there’s a few ways to tackle it
The messages are very basic -
ID: 0x697 Std Bus: 0 Len: 8
Data Bytes: 0x0D 0xBE 0xEF 0x00 0x00 0x00 0x00 0x00
ShiftCommand: DRIVE_SHIFT_COMMAND
Data Bytes: 0x0E 0xBE 0xEF 0x00 0x00 0x00 0x00 0x00
ShiftCommand: NEUTRAL_SHIFT_COMMAND
Data Bytes: 0x0F 0xBE 0xEF 0x00 0x00 0x00 0x00 0x00
ShiftCommand: REVERSE_SHIFT_COMMAND
I’m not sure how to set any of those options up. Can you point me in the right direction to a website or video on how to do that? I haven’t been able to find anything on setting up tables with button states. The software is so flexible yet the user manual is so vague, it assumes you already know how to do all of these things.
This would be a great video for me to do at a future date, but since that takes a while I’m going to set you in a direction first.
First step is always to set inputs, I’m electing to use a single button that will cycle through states.
0 will equal Drive,
1 = Neutral
2 = Reverse
Should probably make the default state 1, but you can tweak that stuff later as desired.
Then we’ll make a table that essentially just converts the button state into the numbers the CAN message needs to see.
In the data you posted the first Byte is the only one changing. We take the hexadecimal value and convert to decimal to get the following
0x0D = 13 (drive)
0x0E = 14 (neutral)
0x0F = 15 (reverse)
We then make a CAN export (outgoing message) on the given addess (0x697, Unsure if your data the address is supplied in decimal or hexadecimal. Ecumaster it’s asked for in hex, if the trans wants decimal then change to x2B9)
First Byte will be the table value that changes depending on requested gear, the rest are from the supplied data. When transmitted they are always in hex, so we give the software decimal.
0xBE = 190
0xEF = 239
0x00 = 0 (leave blank is fine)
Make sure the CAN bus is set to the one the trans is on (bus 1 or 2), and that should work.
I hear you on the manual, it’s a natural consequence that the more flexible a software is the harder it is to explain. Trial and error has been the way I’ve taught myself most things in it.
Thank you so much for this awesome explanation!
