Hello, I want to compare the oil temperature in and out, so I set oil temperature and diffoil temperature on the ADU, the oil temperature is shows well, but the diffoil temperature is not showing well, so I would like to ask. In EMU BLACK, the diffoil temperature is showing well, but not in ADU. Even if I set it, it will show as 0. What’s the problem?
Diif oil temp i thinknis not on defoult can stream . You need to send it form user defined stream
What’s a custom stream? I’ll try it first, and if it doesn’t work, I’ll get back to you
2025년 3월 2일 (일) 21:41, P via Ecumaster Community <notifications@ecumaster.discoursemail.com>님이 작성:
