I have an Ecumaster CAN KEYBOARD installed,
and I want to configure the launch function. Activating the launch via the KEYBOARD isn’t a problem, but the issue is that to deactivate it, I have to press the button again. Is there perhaps a configuration algorithm to disable the button and restart based on VSS speed? Or are there any other options to make this happen automatically?
Hi Launch Control is normal a push button. you can play with speed or a timer maybe also put a clutch switch inside
This information didn’t help me. How do I configure it, or what do I need to do so that Launch Control turns itself off on the keypad after stopping?
