Launch control basic advice please
I hillclimb a Renault Clio which has the Emu Black installed. I am an old duffer and would appreciate a simple step by step guide on how to set up the map for Launch control. Thanks
first of all - read all what you can find in google.
for duffer, optimum decision is - go to local tuning shop and tune it.
for a not rich slacker :grinning: -
determine the level of boost that is needed and the RPM at which the launch will take place.
then
set activation RPM about 500-800 earlier
start roll back ign angle to negative values
start add fuel over 100%
when RPM goes high - sligtly cut spark
i prefer to hold angle at TDC (0 angle), not big spark cut. and NO fuel cut, in desired boost and RPM state.
no bangs, no big stress, quite a street setting
for expamle my setup for 0.5 boost (slight lower of spring pressure of WG), and 4 kRPM:
may be not whery best in work, but work:
P.S.: MT, light clutch fx725, DBW
Thank you for your help, all good advice
Hi mate,
Do you have updates about this topic ?
I can’t get the launch control working too on V3 …
LC state stays to inactive
