Injector dead time - how to read that without factory data?
Hello!
I have new injectors from aliexpress 800cc/min side feed for subaru (yellow) 16600-AA170 and have no more data.
I think to assembly these to fuel rail and do measurement. But with Output test I don’t have precision opening times to make measurements in which time thay opens and inject some fuel out (fuel rail is outside engine).
Is it good measurement to set opening time from 0,4 ms and add 0,1 until fuel goes out? And when fuel starts going out by for example 0,9ms than approximate injector opening time is 0,8ms. All measurements with 13,8 volt stabisiled supply connected to baterry and 43 psi fuel press.
If this method is correct, it would be very good if the ECUMaster added this option in the software.
It is better to inject for example 100 times 2ms and 100 times 4ms. Then based on injected volume you can easily calculatee the dead time. It takes into consideration both opening and closing time.
Other method is current probe.
Monitoring current with the scope when injector opens, you can spot easily the point when the needle starts to move.
It’s also possible to get extremely close dead time data with a knock sensor pressed against the injector body and an oscilloscope hooked to injector output and knock sensor. This won’t tell you about fuel flow, though.
See this video from Shane Tecklenburg. I used ID1300 injectors and entered exactly the data published from their website. This had 1.035ms at 14v 3Bar pressure. I noticed fluctuations with O2 when my headlights turned on. After going through Shane’s method, I measured 0.60ms dead time at 14v 3Bar. Way, way off! It was hard to believe, but now I don’t care what data I find even from ID. I’ll be testing from now on. Backed up my results with batch injection vs sequential for both dead time data and found that my dead time with Shane’s directions gave very close real dead time values.
Very nice methode. Gone try it out as well !!
I tried out measuring the injector delay with a scope and a knock sensor and it worked perfectly!
On further thought, I’m unsure if this value changes under pressure. I measured the dead time the same way that the linked video showed, IE in free air with no pressure on the injector.
I’m thinking about building a single injector holder to test this again under pressure. If it changes significantly that means it is required to measure this under pressure. In either case I’m pretty confident that the knock sensor is an acceptable method to detect when the injector is fully open. Just a question of if it changes under pressure enough to matter.
Yes, times change with total system pressure, voltage and differential pressure across the injector. Meaning manifold pressure also changes how an injector can open and close.
Then yiu have linerization to account for.
Interesting, that makes sense to me. The issue is that the EMU Black only has one table for injector dead time. Is it just assuming a constant dead time?
Is it known what pressure the injector cal table is assumed to be measured at?
I am building a rig to measure this under pressure, right now I’m assuming 43.5psi is the right value. That’s a total guess though.
Yeah update on this:
Do not do this knock sensor method, its completely wrong. My VE was implausible, and the car couldn’t maintain consistent lambda.
I did the standard flow test method for finding dead time and found reasonable numbers which have exhibited much better performance in real life.
Use this method:
I did it in the car, turned on the fuel pump with the “invert output” function on the fuel pump output window and then used the output test function to pulse an injector how i wanted. Took the fuel rail out of the manifold and put a graduated cylinder under the injector I was testing. Was simpler and more accurate. This also ensures you’re doing it under the right fuel pressure and with gasoline in the injector, both of which effect flow and dead time.
Can you explain how did you use function ?
The relation to pressure is irrelevant in the typical ranges of 2-5 bars. There u can assume it to be constant. The options in the EMU are enough and it is wasted time to give it a pressure relation.
The problem with the knock sensor method is that it tells u when the injector is completly open…but what u actually wnat to know is when it starts to open.
The best way is to first determin the static flow and then do a lot of short pulses…measure the actual flow. With the difference to the theoretical flow based on static flow u can calculate a deadtime, which also includes the none linear behaviour in opening and closing phase. Thats the only accurate method. Everything else is just rough guessing.
For a practical scenario
I performed 1,000 injection events at varying pulse widths 2 ms, 3 ms, 4 ms, up to 20 ms on a single injector and recorded all the results.
Based on these measurements, calculating injector dead time doesn’t seem straightforward or meaningful to me.
A more reliable test might holding the injector open continuously for 30 seconds to 1 minute and measuring the total flow, lets say 500 cc over one minute. At this duration, the impact of dead time becomes negligible. This total flow rate could then serve as a baseline to estimate expected fuel delivery at shorter pulse widths (2 ms pulse). By comparing the expected and actual delivered volumes from those shorter pulses, the difference could reveal the true dead time.
But continuously energizing an injector for that long could potentially damage it, Can you explain what i am missing ?
Thats exactly what i wrote.
But no….continous activation cant dmg the injector if ur doing it correctly. If u have HiZ injector tehre is no problem….if u have a low Z one u need to current control it.
yes as @derUltraTT said the better method is to get static flow and then short pulses.
@sourcerer the function is under tools>test outputs You can select an output you want to test and then how you want to test it. Its easier this way because you dont need to make a test rig on your workbench you can just use the car which is already wired up to work right
All you do is start at a pulse width that is so low nothing comes out, and plot flow rate in cc/sec vs. pulse width on a graph. Increase the pulse width until the flow rate plateaus. Then you use a line of best fit in the non-linear region of the plot to find the dead time (x intercept). The X intercept should be greater than 0, if you dont get a number greater than 0 you did it wrong :slight_smile:
So lets say you did a 50ms pulse and you did 1000 pulses, that means the injector spent 50 seconds on. You use the graduated cylinder to measure how much gasoline came out in cc then divide it by the number of seconds the injector spent on (50 seconds). That gets you the flow in cc/sec for a 50 ms pulse.
Then you make the pulse longer and longer until you keep getting the same flow every time, then you make it shorter and shorter until the injector stops working.
Thanks for confirming @junits15 . We did a test on my car and found a bug in the test screen. It is skipping odd numbers and dropping to the closest lower even number as the output. We checked with a scope and confirmed it. If you want to test it yourself, be careful.
@sourcerer very interesting, thanks for posting this because that could definitely trip someone up.
this likely means the numbers I measured are incorrect. I’ll have to give this test another shot and see what I can get out of it now…
I love this! I think this is one of the most valuable video lessons Shane has ever filmed. The coolest part of it is that once you see what the Injector Open Current Waveform signature and the Injector Closing Voltage Waveform signature look like, you don’t even need the knock sensor trace which means you can do this with a cheap single channel pocket scope.
One thing I didn’t make clear was that you have to capture the data with a pulse width that gets the injector fully open and stays open for a moment. I performed the test on a running engine with one injector turned off. I sent a single 5ms pulse to that injector for my measurement. If PW is too short, you may only get a partial opening or less distinct pintle stopping noise.
My sequential vs batch injection test was with data at higher MAP and PW over 2ms. Idle and light load data will often have the non linear range of the injector skewing the results.
That method isn’t terribly accurate, the sound of the injector is not necessarily corelated with the dead time. The sound the knock sensor picks up is the pintle hitting the seat or the end stop, but the injector starts and stops spraying before that happens.
You’ll get higher numbers than reality with that method, verified myself.
Better to do measured flow at several PW’s increasing linearly and then calculate the error as dead time approaches the pulse width.
I just spent some time with pen and paper making x,y axis, (time,volume) to get my brain into the measurement process yourself and derultratt have described above.
It makes a lot of sense when you start to appreciate the relationship between the theoretical perfectly linear static flow graph and the negatively ‘offset’ dynamic flow graph.
Thanks for your input.
