Abarth 500 1.4 T-JET 630cc
I mounted an emublack on a fiat 500 abarth euro 5 with a wiring adapter box.
Compared to the original, the car only has 630cc injectors - 0280158123 (and other changes that make no difference at the moment).
To maintain the idle speed with an AFR of 14.3, it needs values ​​above 90% in the VE table.
After calibrating the DBW (original), if I accelerate the car the mixture is too lean and it shuts off. I’ve already tried putting values ​​of 200% and 300% in the VE table in the area where it turns off and I absolutely can’t get the car to accelerate.
Can anyone help?
I will upload the file I am using on my emublack.
Thankssss
Hi.
do you setup lag time for injectors?
try use from https://www.ms4x.net/index.php?title=Fuel_Injector_Deadtimes#Bosch_0280158123_627cc
could you upload you map from ecu ?
I have got abarth and 0280158123 too, Could you set your injectors on injectors wizard ?
first of all, injection wizard, injectors size, and injection angle
