Injector Output not working
Hello, my problem is on a 5cylinder engine and EMU as an Piggyback for additional fuel injection and boost control that there is no fuel injection on cylinder 1 and 2… You can see that in first step on CAN EGT 1 and 2 and in comparison to 3 -5 the temperature is way higher. And second step there is no output signmal for cylinder 1 and 2. Manually output test for these cylinder works. Back to back comparison with EMU V2 Firmware with the result that all injectors work as it has to be.
Please have a look to my log and software configuration.
V3_Testlauf_Zylinder 1 und 2 ungleich.emub3 (65.6 KB)
Zylinder1_und2_ungleich_den_anderen_egts.emublog3 (5.6 MB)
