Test Outputs for Ignition/Injection 1 to 4 Cylinder Numbers or Firing Order?
Installing a EMU Black on a VW 1.8T 4 Cylinder engine,
Under ‘Outputs Test’ tab, if I test Injection 1, Injector for Cylinder number 1 activates, If I test Injector 2 it activates the injector of the Number 2 cylinder.
Is this correct or should testing Injection 2 activate Cylinder Number 3 as per the firing order ?
Same for Ignition outputs
Thank You
Yes this is all good!
