Injectors work on test but don't work when starting engine
Greetings,
I’m trying to start the engine with wasted spark configuration. I’m changing from Speeduino to EMU Classic. The issue that I have is with the injectors, they are paired 1-4 and 2-3, high-z, using only 2 injector pins. When I run each in test mode, they work, but when I try to crank the car, they don’t activate at all. On the duty cycle it says 0%. Any tips on what could be wrong?
Is you brake switch wired and pressed? If not injectors won’t fire.
Ok, I will try this and let you know.
Without log and project we cant help you.
Here is the emu file that I have: Yamaha FZ6 - Pastebin.com
The pulse width for the injectors is 6ms. Is says that it has sync while cranking.
