Injector phase order
hello, I want to be sure about injector phase. engine is ls3 with wasted spark setup. so ign output 1 is wired to 1. and 6. cylinder’s coil, ign output 2 is coil 8 and 5. ign output 3 is coil 7. and 4. So, when I come to injectors phase section, injectors wired as sequential, injector 1 out wired to 1. cylinder injector, injector 2 output wired to 2. cylinder’s injector and so on and I choosed end of injection. How should be injector phase, when “end of injection” choosen,
injector 1 phase to ignition event ?
injector 2 phase to ignition event ?
thanks in advance.
31 view but no one helps?
If I’m reading this right, I think you’re asking when to end the injection event.
I suppose it depends on what makes most power or best emissions. It depends on your application and measured results.
Could you clear this up better if I got it wrong?
Start at ignition event, squirt twice per cycle, and events per the firing order of the coils.
check the manual:
