Hi all,
Question about injector phasing in batch fire! I’ve searched a lot on this subject, but I can’t seem to find the fitting answer.
I’m helping someone with an 6 cylinder in-line engine. Firing order 1-5-3-6-2-4. Ignition is wasted spark 1-6 pair, 2-5 pair and 3-4 pair. Ignition is verified, timed and it starts when introducing fuel out of a bottle.
Apparently the fuel injectors are also paired! So 3 injector outputs are used for 6 injectors.
Injector 1-6 paired
Injector 2-5 paired
Injector 3-4 paired
How would I set this in the EMU software?
Would I only set Injector phase 1 to 3 with squirt twice per cycle?
(All 6 injector phases were set, but that obviously causes issues when only 3 outputs are used)
(The wiring loom is already there, don’t want to split the injectors if not needed)
Another example would be running a V12 (12 injectors) with an EMU Classic which has 6 injector outputs.
