Lambda Table vs Target
I’m just wondering what would be influencing the Lambda target other than the table.
At idle, or even under driving conditions, my lambda target is always slightly lower than the table. Should be at 1, but its always hovering around .98 or .97 and I have no idea what’s changing it.
I’m not sure if this discrepancy is causing my STFT to take or add fuel or if the STFT IS the cause of the target change. Maybe its just a glitch, idk…
lamdaTRGT.emublog3 (52.3 KB)
2.5.emub3 (71.0 KB)
You are using IAT to offset the lambda target.
Ok thank you, not even sure how that table got anything in it. I appreciate you.
