Lap Timing issues on Lausitzring
Hi all,
we encountered big issues regarding lap-time recognition on the DEKRA Lausitzring again last weekend.
The GPS signal is very good, but only every 3rd or 4th lap is correctly timed since the GPS signal has such a wide spread.
The Lap-recognition works fine on other tracks with the same car. Only the Lausitzring bothers us and other ADU users every year…
I attached a picture of the GPS signal during the race and the same thing from the same car a few months earlier on the Nurburgring. I hope that makes the problem clearer…
can the lap-timing in DataMaster and the ADU be improved to be more robust against a bad GPS signal?
Every help is apprecciated :slight_smile:
Laptimes Lausitzring:
GPS-Map Lausitzring (GPS is all over the place)
Nürburgring looks fine in comparison:
Could you provide the logfile from Lausitzring on which this issue is visible? If you have logs from older runs, they would also be valuable.
The same applies to the ADU project. Could you share it?
If you do not want to share it here on the community, could you send it to me via DM or to e-mail: maciej.fudala@ecumaster.com
As I recall Lausitzring, there are perimeter walls all around it. GNSS signal reflections (multi-path reception) can cause incorrect position calculations and high-update receivers are particularly susceptible to this. Which version of the GPS2CAN are you using?
@mfudala_ECUMASTER Are the GPS2CAN v1 and v2 multi-band/frequency* receivers?
Multi-band receivers are more resistant to false path/multi-path errors.
*) Multi-band/frequency is different from multi-constellation (GPS, Galileo, GLONAS, BeiDou)
@kaihp These are multi-constellation receivers, not multi-band.
These errors can be caused, as @kaihp wrote by multipath reflections that contaminate the base signal from the satellite.
Your logs and project would be valuable to help find a way for the ADU lap timing algorithms to recognize this scenario better. Generally, laps in ADU are not counted, and the whole lap timing goes bad because the start/finish line is not recognized, due to GPS path drift.
Using your logs, we can try to find a solution for this kind of issue.
Second question: Would you show us a photo of how your GPS antenna is mounted?
Hi all :slight_smile:
Thanks for your answers, that might actually explain the issue.
I’ll send you the log via email since its too big to upload here.
And the GPS antenna is mounted directly below the rear window facing clear blue sky. That should be ok I guess?
@DanielStr were you able to figure out what the problems are cause by?
Typical “puck” type antennas like to be mounted in the middle of a metal panel. If you place it on the roof, don’t place it right next to the windows, but more centered so its surrounded by a metal ground plane. I’ve seen 10cm in all directions mentioned. That would help with reception.
