Track Maps on circuits with multiple layouts
This weekend I’ll be using my ADU for the first time. I’m racing at UK Brands hatch, but I’m using the shorter Indy circuit and not full GP Circuit. Will the lap timing work correctly automatically or will I have to do anything?
It only has 1 start finish straight, from ADU laptiming perspective there is no difference between the 2 layouts
If the start/finish line is in the same place as in predefined track, lap timing will work fine without any additional action from your side. If the start/finish line is in a different place, you can define this track layout as a user-defined track or by using the user-defined track button.
You can find more information on how to configure a user-defined track or the user-defined track button in the user manual starting on page 150.
Lap distance is different so predictive lap time wont be right
Great thanks for that. Will the predictive lap time be correct also?
Yes if you set it with button defined start ginish line yes.
