Hi I want to drive directly 4 lpg injectors.
What I need the injectors is stag brand 3Ω
I don’t want to use piggyback ecu I have problems cuffs and misfires
Those are low Z injectors, which need a current control. Emu black is not able to do this. I would stop useing them…they can die if not current controlled.
I had the same issue with LPG injectors…u can try a pre resistor to lower the current. In my case it is working…somehow. But the accuracy of injection is bad and with low injection times just hardly working. I would not recommend this.
Real solution is useing a peak and hold current controller.
