Map based accel fuel
Have a customer that is unable to install a tps sensor without moving a factory fuse box. Are there options for MAP based accel enrichments?
It is possible in Black V3 software.
But there is a bigger issue - idle activation.
How do you expect to have idle control without TPS/PPS?
Found the v3 software in experimental downloads, will play with it after converting and ensuring all is correct
Use of throttle stop and ignition control will handle idle very well.
ECU has to know when to enable the idle control.
The idle control is activated based on pedal position.
An idle system cannot be active all the time.
There is no way around it.
You either need a sensor at the throttle or the pedal.
