MFD15 gen 2 with pro8 issues
I connected the MFD15 gen 2 gauge to canbus from the pro8 and I cant get it to display any data using the Emu black or classic tri file. I connected it to the wires going to the canbus to usb adaptor. Gauge shows it is connected to canbus as the network connection icon is green.
Have you enabled the EMU Black CAN stream and selected the correct bus in the communication settings?
I was wondering if I needed to activate the other can network or if i could just use the already active can 2 line going to the can to usb adapter. Will try that.
