Mini R53 Ecumaster PNP is not sending a signal to the coil
Hi, if anyone could help me, the ECU isn’t sending a signal to the coil. I’ve checked everything; the ECU works except for the signal to the coil.
Can you please share the project file and and some logs where you are trying to start and it doesnt start?
are you using the base map from the website?
